With the first green image where is that in relation to the image i sent you of the board ?
top right
Just to be sure i am connecting power to the wires that come from the rear of the unit correct,as in the red yellow & black above ?
yes
Powered up like this,
Red & Yellow wire joined together outside of radio with positive supply.
Black also joined outside of radio with negative power supply.
Readings taken from brown side circuit board as in photo
JW201 = 12.22v
JW202 = 12.23v
JW216 = 12.22v
JW217 = 12.22v
JW215 = 12.23v
JW214 = 12.22v
JW394 = 12.22v
Just wondering if you had chance to look into this issue ?
Can you show me on my photo which items are we talking about please
Then just to be sure i did it again as shown in blue.
Neg on pin 1 then pos on each other.
I bet if i did it again now it would be different again.
So this item is the reg chip ?
If so will there be numbers on it so i can look for a new one ?
