Hello, i just follow simple circuit to make car ignition cut off, in this circuit when button press, relay will give signal to second relay, and the second relay will self hold. But the problem is, when i start car ignition switch, the self hold relay terminated.
So i replace self hold relay supply with direct battery, the problem is i need to add some switch to cut the hold relay. Anyone have circuit that off delay switch will so i can apply to cut off the direct supply line?
