I've been trying to find some capacitors for a project i'm working on. I'm able to find the capacitors with all the specs i need except the tolerance rating that is recommended.
I'm not finding these capacitors anywhere with the 50% tolerance that is recommended.
What would be the solution?
All of these are for a power supply:
100 u* * * 50% * * 16V * * * EL ----------------- Length: 15mm* Width: 9mm
2.2 m* * * 50% * * 16V * * * EL*----------------- * Length: 32mm * Width: 17mm
2.2 m* * * 50% * * 25V * * * EL *---------------- * Length: 41mm * Width: 19mm
2.2 m* * * 50% * * 25V * * * EL*------------------* Length: 41mm * Width: 19mm
2.2 m* * * 50% * * 35V * * * EL* --------------- * Length: 41mm * Width: 22mm
Thanks!
Thanks!
