Capacitor for crystal
C
ClueLess
For very slow crystals it is necessary to add a series resistance in the crystal
circuit. How do you calculate its value with respect to the two capacitors that
connect the crystal to the ground?
R
Rich Webb
First I'd read the datasheets and/or application notes for the
microcontroller and for the crystal under consideration.
S
Spehro Pefhany
The resistor is there to limit drive power.. so it depends on crystal
characteristics (ESR, max drive power) and other things (drive
voltage, load caps). It's not a straightforward calculation,
particularly if you want to minimize power consumption and/or drive
power. Overdriving the crystal can lead to excessive drift or failure.
Typically 32kHz-ish crystals have *maximum* drive powers in the 1uW to
100nW range.
Best regards,
Spehro Pefhany
C
ClueLess
100nW range.
Thanks for your response.
Actually the micro is running slower, say about 5%, than what it should (a
thirty second operation takes place in 31.5 seconds) so I was wondering whether
the RC values have any bearing.
Perhaps I should try to change the C value by inserting a trimmer instead of the
fixed cap.
Thanks again for your time and help
