Can we use 5VDC LED in the AC line to show indication
Discussion in 'LEDs and Optoelectronics' started by strameshkumar, Aug 30, 2016.
Thread Status:
Not open for further replies.
  1. strameshkumar
    strameshkumar
    Feb 23, 2012
    24
    Hi All, I am creating this design . The LED is 5VDC and take 40mA current. 10K Resistor is 0.25W. can this LED glow when the fuse blown ? Or It will glow in all time ?
    #1
    1. Advertisements
  2. strameshkumar
    shrtrnd
    Jan 15, 2010
    3,552
    430
    Arizona
    If that fuse blows, you'll have 208VAC across a 10K Ohm Resistor and an LED.
    What do you think is going to happen?
    Why don't you just use a neon bulb?
    shrtrnd, Aug 30, 2016
    #2
    Minder and duke37 like this.
    1. Advertisements
  3. strameshkumar
    duke37
    Jan 9, 2011
    4,928
    642
    Derbyshire. UK
    The current will be about 20mA AC.
    The power in the resistor will be 200*200/10000 = 4W so a >5W resistor will be appropriate.
    The led will pass current in one direction and will burn out when the polarity changes. One way around this is to use two leds in inverse parallel.
    If the fuse blows, then the circuit will not be isolated and will remain a danger.
    duke37, Aug 30, 2016
    #3
  4. strameshkumar
    Minder
    Apr 24, 2015
    2,499
    509
    Canadian Midwest
    As per post#2 use a neon, this is how it is done in industrial fuse holders to indicate blown fuse.
    M.
    Minder, Aug 30, 2016
    #4
  5. strameshkumar
    AnalogKid
    Jun 10, 2015
    2,121
    595
    Ohio - GMT-5
    In place of a 10 W resistor you can use a 0.5 uF film capacitor rated for the AC voltage. But you still need either another LED or a 1N4007 diode in reverse parallel with the LED. And the downstream devices still will be dangerous when the fuse blows.
    ak
    AnalogKid, Aug 30, 2016
    #5
  6. strameshkumar
    davenn Moderator
    12,596
    1,558
    Sydney, Australia
    If you have to ask this, then you probably shouldn't be playing with mains voltages
    thread closed for everyone's safety
    davenn, Aug 30, 2016
    #6
    1. Advertisements
Thread Status:
