Hello,
I'm currently working on a project. For this project I'm using a slipring rated:
Voltage: 240 VAC/DC
Current 2A per circuits
Circuits: 12
My plan is to supply current and signal to servos through this slipring, and I'm little unsure about if the wire/slipring will handle the current. I've planned to supply enough current for all 6-7 servos to be funcional at the same time.
The Power supply itself would supply with 5v and 10A.
The signal would come from an arduino, with a power supply by itself (9v battery). I know the basic wiring to have all ground connected together, to avoid problems between two power supplies.
What I'm wondering is if there is any essential things I would need to think through when it comes to the wiring through the slipring. As I've pictured. When the servos draw more than 2A together, there will most likely be more than 2A going through the positive- and ground wire. The splitting and distribution will happen above the slipring. and wired up parrallell to give equal voltage.
With more than 2A (let's say 10A) and 5v, through the slipring in a single wire, would it for sure ruin it?
Is there some tweaking I could do? And is there something I've forgotten when it comes to putting on a P.S. with 5v and 10A to the servos. And if only 1 servo is going. Will that servo be safe with a 5v 10A P.S.?
I'm new to the understanding of Power Supply, I would appreciate if you took your time.
Voltage: 240 VAC/DC
Circuits: 12
