K
KJ
Can the physical placement of frame ground to ground connections cause
a resonance that would allow EMI to radiate at or around those resonant
frequencies?
I have a rectangular multi-layer board (16"tall x12" wide overall)
which connects mechanically to the metal frame along the two 16" sides.
The top and bottom layers of the board are frame ground planes which
connect directly to the mounting holes along the two sides.
Around the perimeter of a rectangular sub area (15" tall x 8" wide) are
32 .01 uF bypass caps that connect between digital ground planes and
the frame ground planes. I followed all the good EMI design rules and
such and of course things still ended up radiating out the I/O cables
anyway so I clamp on the ferrites to pass certification and move on.
The only problem frequency was the 4th harmonic of the oscillator on
the board.
I got to wondering though if the physical placement of the connections
between digital and frame ground might have been the cause of the
troubles. The straight line path between any two connection points
would seem to define a possible 'half wavelength' that would have nodes
at the connection points. Taking the x,y coordinates of each of the 32
connection points and computing what the offending frequency would be
resulted in a list of 512 frequencies, the lowest seven of which were
below my 4th harmonic.
So did the location of these 32 connection points then create a sort of
bandpass filter that allowed all my 4th harmonic stuff to leak right
out? If so, just what is the mechanism for it to do so?
As far as I can tell, I just might have found an interesting
coincidence for this particular board between 'half wavelengths defined
by my frame to digital ground connections' and the problem frequencies
that showed up in testing and haven't got any theory that would connect
them. I was planning on testing the hypothesis somewhat by adding some
connections between digital and frame ground in a few places in the
'middle' of the rectangular area to see if that snuffed out the problem
at the 4th harmonic since now the longest 'half wavelengths' would be
roughly half the size they are now which would mean I'd be good up to
the 8th harmonic.
If the digital to frame ground connection locations as I've described
them a contributor to the problem, and if so, why? Does anyone have an
explanation for why the current would be doing this? Or was this just
like I said, an interesting coincidence for this particular board?
KJ
frequencies?
the board.
the 8th harmonic.
KJ
