Can I Connect a DC-DC step up converter to a USB powerbank?
Reven Moodley
Aug 25, 2016
3
Aug 25, 2016
3
I have a Canon DSLR Camera, I have been looking online to buy a Dummy battery pack with with wires (SEE IMAGE BELOW)
and connect a external power pack to the wires to be able to run my camera for long periods of time,
My question is that a powerbank Makes 5v and I Need 7,2v to run the camera,
Could i connect a DC-DC step up converter to the usb port of the power bank, and turn it into 7,2v which then connects to the dummy battery?
my previous idea was to buy a 12v battery pack and use a DC step down converter, but I found a really large high capacity USB power bank, and realised it would be more useful because on times I don't need to use it to power my DSLR i could use it to charge my cellphone and other devices
Thanks For the help
Alec_t
Jul 7, 2015
3,587
Jul 7, 2015
3,587
Are you sure that you camera can run for extended periods without over-heating?
Reven Moodley
Aug 25, 2016
3
Aug 25, 2016
3
Its more for cases when i do timelapse or hyperlapse photography, so i would hope its not overheating?, but even when i use magic lantern powersave mode, I can only get about 3 hours worth of time from a canon battery.
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
That camera will be fine powered on for ever :). They can get a bit warm if you do extended video or continually fire the flash
KJ6EAD
Aug 13, 2011
1,114
Aug 13, 2011
1,114
There are several multi voltage power banks on the market. Only one I know of that will supply the voltage you want, or close enough. I've been using the Powerstream MP3450 for about three years now.
Reven Moodley
Aug 25, 2016
3
Aug 25, 2016
3
if the battery I get is a 5v 15000mAh battery, roughly how much will I lose when I use the DC 7.4v step up converter ?
KJ6EAD
Aug 13, 2011
1,114
Aug 13, 2011
1,114
You can expect a capacity of approximately 7600mAh.
