D
Daaavey
QUESTION:
I have dozens of 12v, 9v, 6v, 5v, 4.5v, and 3.7v power adapters laying
around, but need a 24v 2a power supply. I know with batteries you can
simply daisy chain them together (sequentially) to attain higher
voltage (as is done in most electronic devices) or in parallel to
address higher amperage needs. Is there a simple way to do this with
power adapters? (could I throw the inner workings of two 12v 1a power
supplies on a board, and connect them in such a manner as to acheive
the equivalent of 24v 2a? My guess is no. If not, is there some way I
can somehow utilize parts from my vast collection of powers adapters,
to create a 24v 2a adapter?
SPECIFICS:
Let me preface the remainder of this by saying that I have no training
whatsoever in electronics, or circuit design, other than what I picked
up from my "101 in 1 electronics set" when I was a child. I am
however, (I've been told) pretty sharp, and due to an overwhelming need
to understand how everything works, have learned a few things over the
years (mostly by taking things apart), and am now able to diagnose and
repair most broken home electronics that I have so far encountered.
(DVD players, CD drives, laptops, desktop computers, monitors, tvs,
whatever) I have deduced that most electronics malfunction due to a
failed connection of some sort rather than bad components.
I have an old iBook (Blueberry), which no longer has a power adapter.
(in retrospect I should have saved the part, which only had a frayed
wire - and had caused a short) Apple incorrectly diagnosed the iBook
as "fried" along with the power adapter. (my 2nd replacement, the first
two adapters met death in the same manner - frayed connector)
I have since determined through tinkering (and plugging in a friend's
adapter) that the iBook is functional. In fact, now it works better
than it did before! (Due to the fact that I thought it was broken, I
have since fully dismantled the iBook in order to understand it's inner
workings, and in doing so, discovered the source of the CD drive
failure (bad CD-ROM drive which I replaced with a CD-RW from my Dell
that just happened to fit), and the USB port failure, (broken
connectors) and repaired the USB port by hammering copper speaker wire
flat then bending it into shape, and replacing the 4 contact points
inside the USB port, which I then saudered to the motherboard. (I
didn't have enough "wire" to apply sauder to when I first attempted to
simply sauder (together) the original connectors that had broken))
What I need is a 24 adapter, which I would prefer to make one myself
rather than pay money money for another crappy replacement that will
eventually fray again anyway, I am unemployed right now, so I can't
really afford a new one anyway.
That being said, do I really even need 24v? I know just about all
computers that I have tinkered with seem to have two internal supplies,
12v and 5v. (all devices/boards are subsequently designed to use one or
in some cases both of these power supplies, at least this has been my
observation) Would there be a relatively simple way to connect a power
block from one of my old desktop macs? (I'm assuming that the 24v DC
gets converted to 12v, and 5v immediately after the power enters the
computer. Where would I want to connect the 12V & 5V? (what am I
looking for on the motherboard? unfortunately everything is very small,
and labeled only with letters and numbers that no doubt mean something
to someone with an Apple iBook Repair manual but are apparently
meaningless without one.
And, as for the jack, I already have this covered. (It's just a mini
stereo jack. the outer connector simply powers the light on the jack
reciever) (Although if I decide to use a power brick from a destop Mac,
I will fashion a new conncector of some sort. I suppose just a standard
internal power connector (Red, Black, Black, Yellow) for desktop
computers would suffice, and be otherwise appropiate.
I welcome your comments and suggestions!
David Franklin
SPECIFICS:
David Franklin
