Attached is a schematic. The two voltages are unknown and could be different values. Both are after some circuit above them, also unknown. The circuits are separate from each other above the point of voltages.
Assume the entire circuit uses the same power source.
Up until now, I thought the connection of those two schematics is exactly the same thing, just different points.
1. But then I questioned the behavior of current, and wonder if it would sometimes be better to wire it one way over the other because of this. Is this ever a consideration? Or are those setups exactly the same and current adjusts behavior such that it would work?
2. For example, lets say currents from both of those voltages both share load 1 and load 2. This makes sense in setup 2.
In setup 1 only one load appears to be able to be shared, either load 1 or load 2, unless current is able to flow in two directions in the same wire simultaneously. For example, assume load 1 is shared, load 2 would have to get its current from the left "+" because current from the right "+" is blocked from going to the left due to opposite directions of current as shown by the arrow with a question mark in the attached picture.
Is this possible?
I hope my explanations make sense.
Is this possible?
