Can anyone point me in the direction of high amperage 5 volt power supplies?
C
Coleston
Say power factor corrected and 10 amps capability.
Also, any pointers on how to adjust power supply voltage and current
independantly with a microcontroller would be helpfull, I know atmel
and pic very well, so anything in those assemblers would be ideal.
Thanks.
-Coleston
P
Phil Allison
** Groper alert !
** A 50 watt PSU does not need PFC.
Total wank.
independantly
** Not even possible.
If you adjust the voltage - the load determines the current flow.
If you adjust the current LIMIT - the load will determine the voltage.
** Some Lab DC Supplies have remote control of output voltage and current
limiting by a 0-10 volts signal.
Use Google to locate them.
Won't be cheap.
.......... Phil
