D
David Lin
I am trying to drive a permanent magnet synchronous motor(PMSM) with
pure sinusoidal drive voltage instead of SPWM. So I tried to use three
power amplifier OPA547 to amplify the 3-phase sin voltage input to
drive the motor. But the outputs of the OPA547 have obvious distortion
when the motor was at standstill or when it rotated. Then I tried to
drive the motor in 6-step stepping mode still using the OPA547, and
this time, the the outputs of the OPA547 have no distortion when the
motor was at standstill, but they distorted when the motor was
rotating. It seems the distortion was possiblly caused by the back
EMF. But why the power amplifier's output can be affected by the load?
Does anyone know how to drive a PMSM using linear power amplifier
instead of SPWM? If the OPA547 is not the right chip, which chip
should I use? Thanks a lot in advance.
