Jerry Napoliano
I have a Caddx NX-8, with (2) 1448 keypads. All was well with it
until today, when I added 2 smoke detectors. They are the exact same
model as those which were in the system already, they were paralleled
in and no changes were made inside the panel to the fire alarm
circuit. I did disconnect the AC inside the panel, as well as the
backup battery, siren, and RJ-48 while I did the upgrade, however all
connections were remade when I was done.
I tested each of the new detectors, and they work fine. The reset
function via the panel works fine as well. The service light is on,
though, and doing a *2 from the keypad shows a fault #8 which is a
"Ground Fault"
I'm not clear about what that is indicating, and am looking for
suggestions on where to begin troubleshooting.
Thanks all.
"Ground Fault"
Thanks all.
