Button to button circuit
Chris Johnson
Nov 12, 2017
Nov 12, 2017
I have a little pitbike. Just wired a 12 v AC to D.C. Rectifier to the power output then to a wire harness connected to a light on the front. I also have a horn I want to add, but don't want o accidentally activate both on the off chance and stall my bike. Is here a way to wire my light switch to render the horn button useless when active?
Bluejets
Oct 5, 2014
6,939
Oct 5, 2014
6,939
Don't know the reason for rectifier but in answer to your query, perhaps just a simple changeover switch.
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
Maybe rectifier is needed because maybe the bike has an alternator and the light is an LED?
Bluejets
Oct 5, 2014
6,939
Oct 5, 2014
6,939
Maybe the light is a headlight and maybe the horn is DC.... maybe.. maybe
CDRIVE
Hauling 10' pipe on a Trek Shift3
May 8, 2012
4,960
May 8, 2012
4,960
Why would blowing the horn while the headlight is on stall the bike? Btw, what's a Pit Bike?
Chris
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
I think the light is a high power searchlight and the horn is the high current one from a fire truck.
Then the engine has no spark when both are turned on. No battery?
CDRIVE
May 8, 2012
4,960
May 8, 2012
4,960
EEK! :eek: Thanks for the enlightenment.
Chris
7,682
7,682
Yes, use an SPDT momentary switch for the horn, and an SPST toggle switch for the light.
If you have the light switch off, the horn will operate normally. If you have the light switch on, pressing the horn button will turn off the light while pressed.
CDRIVE
May 8, 2012
4,960
May 8, 2012
4,960
Bob, what are those other 2 schematics for?
Chris
7,682
7,682
Whoops, I posted it three times and deleted the embedded image, but it guess that did not remove them entirely.
7,682
7,682
The schematic that I accidentally deleted from my earlier post.
