Bright stripe on LCD display
Discussion in 'Electrical Engineering' started by DaveC, Jul 26, 2013.
  1. DaveC
    DaveC Guest
    This is a ~ 4 year old HP Pavilion laptop with LCD display.
    There is a bright vertical area on the left end of the display that is
    incongruous with the rest of the display. It is only on the left end.
    http://imagebin.org/265633
    This image also shows the lighter central area of the display which is an
    artifact of just viewing it on-center (or nearly). This phenomenon can be
    ignored.
    Is the stripe due to LCD problem? Or...?
    Thanks.
    DaveC, Jul 26, 2013
    #1
    1. Advertisements
  2. DaveC
    Martin Brown Guest
    > ignored.
    It is such a terrible photograph that it looks mostly like a reflection
    of something white you left on your desk off bottom right. It doesn't
    look abrupt enough to be an LCD connection defect which tends to give
    very sharp linear errors on bit/byte/word boundaries.
    Looks to me more like a physical fault with the backlighting optics. An
    impression heightened by a dark ridge to the RHS of the brighter patch.
    Regards,
    Martin Brown
    Martin Brown, Jul 26, 2013
    #2
    1. Advertisements
  3. DaveC
    Baron Guest
    Martin Brown Inscribed thus:
    >> is incongruous with the rest of the display. It is only on the left
    >> end.
    >> is an artifact of just viewing it on-center (or nearly). This
    >> phenomenon can be ignored.
    > reflection of something white you left on your desk off bottom right.
    > It doesn't look abrupt enough to be an LCD connection defect which
    > tends to give very sharp linear errors on bit/byte/word boundaries.
    > An impression heightened by a dark ridge to the RHS of the brighter
    > patch.
    I would agree ! Probably a defect in the backlight tube/tubes.
    Best Regards:
    Baron.
    Baron, Jul 26, 2013
    #3
  4. DaveC
    DaveC Guest
    I've seen dark bands before (burnt out tube) but never a bright band. I
    suppose all but one could be dimmed...
    DaveC, Jul 26, 2013
    #4
  5. DaveC
    Baron Guest
    DaveC Inscribed thus:
    > I suppose all but one could be dimmed...
    > Thanks,
    > Dave
    The tubes blacken at one end more than the other, so the brightness gets
    turned up to compensate causing a bright area at one side. Double tube
    displays do the same but because one tube is at the top and the other
    at the bottom the bright area tends to be towards one corner.
    Best Regards:
    Baron.
    Baron, Jul 26, 2013
    #5
  6. DaveC
    DaveC Guest
    So replacing tubes should resolve issue?
    Thanks.
    DaveC, Jul 26, 2013
    #6
    >>> end.
    >> patch.
    I have a 32" Viewsonic from the early 2k years. It has a streak of
    altered color that appears almost exactly as yours. It has to do with
    the sheet the backlight has in front of it. If it changes the way light
    diffuses through it, then said lighting will no longer be homogenous
    across the entire surface, and the coloration of that area gets affected.
    I looked at mine again after it sat for a couple years, and it looked
    like it had healed. But a few hours later, it slowly returned. Which
    makes me think that the LCD panel itself may have suffered some kind of
    incursion or temp based morph that did not get carried evenly across the
    panel surface.
    I guess we will not find out until an LED backlit display gets affected
    and we get to see any differences.
    DecadentLinuxUserNumeroUno, Jul 27, 2013
    #7
    1. Advertisements
Similar Threads
  1. Lorz
    920
  2. Christian
    LCD-Display TLX-1501-C3M / Display-Controller M6355
    Christian, Oct 9, 2007, in forum: Electronic Components
    1,457
    Gary Tait
    Oct 10, 2007
  3. woodpecker
    DVDs: Picture gets bright-dark-bright-dark...
    woodpecker, Dec 27, 2007, in forum: Electronic Repair
    6
    1,944
    James Sweet
    Dec 28, 2007
  4. DaveC
    DaveC, Jul 26, 2013, in forum: Electronic Design
    4
    346
    Baron
    Jul 26, 2013
  5. DaveC
    DaveC, Jul 26, 2013, in forum: Electronic Equipment
    4
    1,667
    Baron
    Jul 26, 2013
  6. DaveC
    DaveC, Jul 26, 2013, in forum: Electronic Repair
    4
    456
    Baron
    Jul 26, 2013
  7. Nate-00
    5
    200
    Nate-00
    Aug 7, 2016
  8. HellasTechn
    Advice on LCD display for Picaxe project.
    HellasTechn, Sep 29, 2016, in forum: Electronic Projects
    68
    556
    HellasTechn
    Nov 11, 2016
Loading...
