Hi Everybody,
I would really appreciate if somebody could help me with the my problem. I have to design a BP filter between 40 and 80 MHz with the following special features:
1. The noise level is around -90 dBm.
2. The signal is known to have a strong (60 dBm above noise) peak at exactly 80 MHz. This peak must be eliminated. Apart from that it has some standalone peaks in the 0-40 MHz region (~ 30 dBm above noise), and a peak in 40-80 MHz which I would like to isolate (~ 25 dBm above noise).
3. The filtered signal will be used in a feedback loop, so the phase shift should be accordingly small.
Unfortunately, I do not have much experience in filter designing, any help would be highly appreciated. First I have designed a high-order Chebyshev filter, but I have realized that it screws up the phase. Shall I dwell into active filters (any good literature?), can they help? I am absolutely clueless...
