Bouncing cells?
Discussion in 'Electronic Equipment' started by DaveC, Aug 17, 2013.
  1. DaveC
    DaveC Guest
    DaveC, Aug 17, 2013
    #1
    1. Advertisements
  2. DaveC
    Robert Baer Guest
    Jan Panteltje wrote:
    > On a sunny day (Fri, 16 Aug 2013 21:59:11 -0700) it happened DaveC
    > <> wrote in
    > <-september.org>:
    >> That crazy Ozzie is at it again:
    >> https://www.youtube.com/watch?v=PRf9JTg3QwA
    >> Fascinating...
    > Nice,
    > facinating,
    > I just measured the weight of 3 eneloop AAA cells.
    > 2 good ones measure 11.77 and 11.72 gram, fully charged
    > and one that is bad (high Ri) also charged, measured 12.28 gram
    > Later I will measure one of these good ones when it is empty.
    > The bad one (that is heavier!) bounces more...
    Shows that electrons have more mass due to less bounce; heaver cell
    shows that the lost electrons have NEGATIVE weight due to the NEGATIVE
    charge.
    Now combine these effects with a cyclo-magnetic positronator, and one
    can make either a neg-energy generator, or a graviotometric repellor
    (AKA anti-gravity machine).
    Robert Baer, Aug 17, 2013
    #2
    1. Advertisements
  3. On Sun, 18 Aug 2013 05:14:21 GMT, Jan Panteltje
    <> wrote:
    >Forgot to do the bounce test on the empty one...
    The video mentions alkaline batteries. The Eneloop is a NiMH
    rechargable battery.
    Rechargable batteries have a safety valve that will blow off gas if
    the battery is greatly overcharged. This would suggest that a fully
    charged battery has more gas in it than a discharged one. If that is
    correct, it would follow that fully charged battery should bounce more
    than an empty one.
    RoRo
    Robert Roland, Aug 18, 2013
    #3
  4. On Sun, 18 Aug 2013 11:35:19 +0100, "Gareth Magennis"
    <> wrote:
    >Is it not more the case that the amount of bounce has more to do with the
    >shock waves moving through the medium inside the battery, rather than the
    >actual mass of the battery?
    Yes, exactly. Gas is compressible and elastic, while liquids are not.
    Try filling a football with water and see the difference.
    In Kip Kay's video which Dave Jones refers to, it is also mentioned:
    http://kipkay.com/episodes/amazing-way-to-test-batteries/
    RoRo
    #4
  5. DaveC
    DaveC Guest
    > e.g. a battery full of a glass-like medium would bounce more than if that
    > same medium was changed by chemical reaction into a more jelly type medium?
    Weight difference cannot be ignored. Maybe both weight and density play
    roles?
    DaveC, Aug 18, 2013
    #5
    1. Advertisements
Similar Threads
  1. KILOWATT
    The mechanism behind bouncing...
    KILOWATT, Feb 2, 2007, in forum: Electronic Basics
    26
    1,006
    Rich Grise
    Feb 6, 2007
  2. SHIRLEY ANDERSON
    new concept in solar cells: ambient solar cells....
    SHIRLEY ANDERSON, Jan 21, 2004, in forum: Photovoltaics
    697
    Scott Willing
    Jan 21, 2004
  3. Jason Crowell
    Concentrator Cells vs Conventional Cells
    Jason Crowell, Mar 7, 2004, in forum: Photovoltaics
    704
    Anthony Matonak
    Mar 7, 2004
  4. lodevaduh
    860
    55pilot
    Mar 9, 2010
  5. DaveC
    Bouncing cells?
    DaveC, Aug 17, 2013, in forum: Electrical Engineering
    6
    1,909
    DecadentLinuxUserNumeroUno
    Aug 24, 2013
  6. DaveC
    Bouncing cells?
    DaveC, Aug 17, 2013, in forum: Electronic Components
    4
    1,369
    DaveC
    Aug 18, 2013
  7. DaveC
    Bouncing cells?
    DaveC, Aug 17, 2013, in forum: Electronic Design
    4
    450
    DaveC
    Aug 18, 2013
  8. DaveC
    Bouncing cells?
    DaveC, Aug 17, 2013, in forum: Electronic Repair
    5
    528
Loading...
