S
Saman
Hello, I have a board that has 8 transistors mounted on a heat sink. each
TO-220 transistor(IRF 630) dissipates about 10W. for lower voltages I
usually used rubber silicon pads for isolation. I have tested them and they
can dissipate up to 15W without making transistor too hot. Now I have a high
voltage board. the voltage of metal flange(drain) of each transistor is
100V. I haven't worked with such high voltage yet, so I'm worry about
safety. The whole heat sink assembly is inside a metal box that has earth
wire and also both live and null of input 220V line are fused. Still I'm not
sure it is enough. your experience is appreciated. thanks
