That one guy
- Dec 23, 2016
- 17
- Joined
- Dec 23, 2016
- Messages
- 17
Is it possible for a rechargeable battery to be directly charged by a solar panel?
I don't know the capacity of your batteries nor the solar panel output voltage. You can find very cheap modules on eBay for such task. Check this one for 12v battery:How can i include charge management?
It's a standard module... at the few $ value, i think it's worth exploring.That is a nice charging module. I wonder if it is "prime" or is a reject from a manufacturer. I guess you will get your money back if it doesn't work properly and you pay more than its cost to ship it back to China.
I have a colleague who charges lipo batteries this way (in a sealed outdoor device). However he has a shunt regulator across the battery.
This will work well for lipo's and possibly lead acid batteries, but not with nicad or NIMH batteries.
You need to ensure that the charge current cannot rise too high and that your shunt regulator can dissipate the full power from the solar panel.
In my colleague's case the panel supplies well under 1W to the batteries and full charge is achieved in about 10 minutes of full sun after operating overnight.
Yeah it's a low power thing and may not scale really well.
My colleague has a circuit operating from a single lipo cell. It consumes little power and a 6V 50mA solar panel fully recharges the battery in about 5 minutes after running overnight.
If your voltage or power need are significantly greater there may be additional requirements (thermal, balancing, etc.) that will also need to be met.
See here for discussion of the circuit (it is coming up quite a bit at the moment for some reason)
You simply connect the solar panel up to the battery via an isolating diode and place this circuit across the battery to limit the voltage.
The version on that page is to similar a lead acid battery. A change in resistor values is required for a different range of voltages.
The circuit works almost exactly like a zener diode. In this application, any excess current passes through the mosfet. This loads down the solar panel so it can't increase the voltage of the battery above a safe level.
If you have a battery where temperature variation will cause a change in voltage, this circuit could also draw significant power from the battery if the voltage rises due to temperature. (This is a bad thing)
The MOSFET will be called on to dissipate the full power from the solar panel once the battery is charged. So... A 100W panel means the MOSFET could be dissipating 100W.
For higher power applications, a series regulator, possibly employing MPPT would be justified.
This circuit should NEVER be used to charge a battery from a voltage source (e.g. battery or power supply). It is designed for use with current sources or at least current limited sources.
Ok I'm totally with you so far! My question is: is there a way to regulate the max amperage at a fixed voltage? In other words, can I set the output voltage at 14v (using a voltage regulator), and somehow limit the current to only 1A or lower? Kind of like how a fuse works but instead of shutting down the whole circuit, it just doesn't allow the extra amperage through. That way I don't have to worry about the battery pack discharging too quickly. Or am I fundamentally thinking about this wrong?A battery must be charged at a voltage higher than its average discharging voltage.
A battery can have a discharging current much higher than its maximum allowed charging current.
