protoengineer
- Oct 7, 2018
- 2
- Joined
- Oct 7, 2018
- Messages
- 2
Hi all,
Problem:
I have to calculate the base resistance required between a voltage supply and the base leg of a MOSFET transistor, given the following parameters:
1) voltage supply to the base leg is 5V and the emitter leg is connected to ground with the voltage supply.
2) the collector leg is connected to a rectifier diode and solenoid (inductor) which are in parallel with each other.
3) the solenoid and diode are connected to a separate 12V voltage supply which is connected to ground with the emitter leg and base voltage supply.
4) the solenoid operates at 24W with an equivalent 6ohm resistance.
I also have to figure out what transistor and what diode I can use for the system.
My attempt:
I made this SPICE model:
So, I assumed that you could use KVL on the left side of the circuit, with Ohm's Law V=R*i -> 5=R1*i1.
I also assumed that using the equivalent resistance of the solenoid, the current across it can be calculated with P=V*i -> 24=12*i -> i_L1=2A.
So, using KCL, I know that if I choose a diode with a 1A rating, the current into the parallel connection should be 2A+1A=3A.
If I then choose a MOSFET transistor with a gain of 1000, the current out of the resistor should be i1=3mA.
Thus, using Ohm's Law again, with V=R*i -> 5=R1*0.003 -> R1=1667 Ohm.
I know that a 1N4004 has a 1A rating and a TIP120 has a 1000 gain, so if the system uses two standard resistors in series in place of R1 with resistances of 1600 Ohm and 68 Ohm, with a 1N4004 and a TIP120, the solenoid should operate at 23.97W and 12V. The power on the resistors is less that 15 mW combined so a 250 mW rating on the resistors would not be overloaded.
Can someone please tell me if I did this correctly? Thank you very much.
Problem:
My attempt:
