Ballast fault
Michalis georgiou
Feb 13, 2017
7
Feb 13, 2017
7
Hello there, i want help with a ballast fault,
I did wrong connections between L and N and my lamp isnt opening! Do you know if my ballast is burned or its only to change a burned part of it!?
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
Did you blow the tube starter filaments at all?
M.
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
Interchanging L and N should not affect the operation. Please state what you did wrong. Show a picture.
Michalis georgiou
Feb 13, 2017
7
Feb 13, 2017
7
What do you think by this connections? I did it like the electrical diagram and still sot lighting up
Bluejets
Oct 5, 2014
6,927
Oct 5, 2014
6,927
What is the lamp and what is it's rating?
Balast shows compatible with High pressure sodium or metal hallide 400w.
Also wondering if you have ever been around when one of these lamps implode?
Obviously not given your test set-up.
Michalis georgiou
Feb 13, 2017
7
Feb 13, 2017
7
MH Lamp 400w , i did the connections like the diagram but still not working, my cable is 1,5 mm2 and its okay as i know because of the 1,7 amperes . 400w= 230v * 1,7 amps
What do you think i did wrong?
