A
[email protected]
I have used multilayer ceramic capacitors for power supply bypassing
for a cryogenic amplifier. Everything worked fine at room temperature,
however as i inserted the circuit in the cryogenic system, after a
while my resistance of bias line to ground dropped to 18 ohms.
I can't even turn the bias to 1 volts (orignally it was 4 volts at room
temperature) due to the current limit of the power supply.
I have 2 guesses, one c'ld be a short of bias line to ground but i have
used magnet wire so this shouldn't be a case, and i tested the
enclosed system was working fine uptill 77 Kelvin.
Second guess, is that i have many bypass capacitors multilayer ceramic
type which cld go bad (I have no electrolytic caps in my circuit).
Does any one know how these caps behave when gone bad or when cooled to
4 Kelvin or so?
Please help.
4 Kelvin or so?
Please help.
