B-FTP vs B-FHTP Electrical Motor
Discussion in 'Electrical Engineering' started by Buffalo, Oct 8, 2013.
  1. Buffalo
    Buffalo Guest
    I am trying to replace a 120v C-Frame Shaded Pole motor in a kickspace
    heater. It was installed in 1978.
    I can't find that spec ( B-FHTP) but only the B-FTP spec.
    It is a small motor that was made by Gould and it drives a small fan over
    the electric heating elements.
    Type: B-FHTP
    120v 60Hz 0.47a
    301-2754
    Thermally Protected
    So, can a B-FTP C-frame shaded pole motor be substituted for a B-FHTP motor?
    Out of curiosity, what do those letters stand for and any ideas on where to
    find a replacement motor?
    I've been searching on the Internet for over 2hrs.
    Buffalo
    PS: Perhaps not the right ng, but I thought I'd try, esp for the definition.
    #1
    1. Advertisements
  2. Buffalo
    Rich. Guest
    As long as the specs and mounting holes match you can use what you want.
    Try here:
    http://www.grainger.com/Grainger/c-.../ecatalog/N-9y3?Ndr=basedimid10071&sst=subset
    Rich., Oct 8, 2013
    #2
    1. Advertisements
  3. Buffalo
    Buffalo Guest
    "Rich." wrote in message news:...
    Thanks, I 've been on the Grainger site several times. Hard to find the same
    specs and I don't even know what the speed of the old motor is. However it
    is a CW rotation. Since most bathroom fan motors, etc seem to turn around
    3000 rpm, I'm hoping that is what I need or will work.
    Yep, I've matched up the shaft diameter, shaft length is not close (all
    longer), but I can always shorten it with a hacksaw, mounting holes are 1
    7/8"which I can find.
    Any idea what the B-FHTP and B-FTP stand for? Hopefully a B-FTP is
    compatible to the temp rating of a B-FHTP.
    Thanks for your reply.
    #3
  4. Buffalo
    Rich. Guest
    I've never heard of those letter designations before. Those could just
    manufacture codes that mean nothing to the general public. I highly suspect
    the H designates the motor as a heater motor capable of withstand higher
    temperatures.
    Rich., Oct 8, 2013
    #4
  5. Buffalo
    Buffalo Guest
    That was one of my main concerns; the higher temperature environment it will
    be in.
    Buffalo, Oct 9, 2013
    #5
  6. Buffalo
    Buffalo Guest
    Any ideas or thoughts if it just means higher temp leads coming off the
    motor?
    #6
  7. Buffalo
    Buffalo Guest
    "Buffalo" wrote in message news:l33t7o$p13$...
    Can't anyone in this 'engineering' group answer the question or at least
    give me a hint on how to find out the answer?
    Buffalo, Oct 17, 2013
    #7
  8. Buffalo
    Guest
    Moaning is _not_ a good way to encourage answers.
    , Oct 17, 2013
    #8
  9. Buffalo
    Tom Biasi Guest
    I suspect if someone could have they would have, or do you want someone
    to do research for you?
    Tom Biasi, Oct 17, 2013
    #9
  10. Buffalo
    Buffalo Guest
    wrote in message
    I was just trying to apply some pressure to an 'electrical engineering'
    newsgroup.
    Didn't work.
    Hell, I figured engineers would know (or at least give me some hints on how
    to find my answer. I spent several hours Googling, etc.) My mistake.
    #10
  11. Buffalo
    Buffalo Guest
    "Tom Biasi" wrote in message news:1GW7u.25084$...
    I tried researching on Google, etc for several hours. Didn't find it and
    then I found this ng, which has a good sounding name, and thought I would
    ask, what I thought would be a pretty easy question, for electrical
    engineers.
    I guess I was wrong.
    #11
  12. Buffalo
    Tom Biasi Guest
    Did you call the manufacturer and ask what those letters mean?
    #12
  13. Buffalo
    Buffalo Guest
    "Tom Biasi" wrote in message news:fCX7u.23548$...
    The mfg of the motor was Gould.
    I found nothing on their homepage.
    The printing on the motor, which was for a toe-space heater was:
    B-FHTP 120v 60Hz .47A 301-2754 it's rotation is CWSE, rotational shaft
    speed was unknown, no label on the toe-space housing unit itself.
    it is a C-Frame motor. It is used to blow air through a toe-space heater (on
    a 20A 2-pole circuit)
    I did call globalindustrial.com which sells electrical motors and no help
    there.
    The toe-space heater was installed in 1978. Hopefully this info will help.
    Sorry that I didn't provide the above info earlier, but I thought that the
    B-FHTP vs B-FTP was most likely all that was needed.
    Thanks for any additional info or ideas.
    #13
  14. Buffalo
    Tom Biasi Guest
    If you have a Grainger near you show them the motor.
    #14
    1. Advertisements
