H
Harald Mossige
First lab.
reset:
sbi DDRB.0
loop:
sbi PORTB,0
cbi PORTB,0
rjmp loop
then, compile, program and scoop at PORTB,0 gives ontime of 5.3 * 0.2 us =
OK
Then I add it to be:
reset:
ldi r16,0xFF ; <- this is altered increasily by dtep of 0x10
down to 0x0f
out OSCCAL,r16
sbi DDRB.0
loop:
sbi PORTB,0
cbi PORTB,0
rjmp loop
This giv no result at the scoop.
Hvat does I wrong?
Then I add at the end:
reset:
; ldi r16,0xFF ; <- this is altered increasily by dtep of
0x10 down to 0x0f
; out OSCCAL,r16
sbi DDRB.0
loop:
sbi PORTB,0
cbi PORTB,0
rjmp loop
..org 0x3fe
..db 0x80
AStudio3.5 aksept it, but I am not able to program it since STK500 are
oppgraded to AStudio 4.
Compiling width AStudio4, I get the errormessage:
warning: offset 0x7fc in .cseg is beyond end of memory at 0x3ff
warning: end of .cseg at 0x7fe is beyond end of memory at 0x3ff
warning: .cseg .db misalignment - padding zero byte
Howto get the OSCCAL to work
Howto program the calibratingbyte at 0x03FE
HM
reset:
sbi DDRB.0
loop:
sbi PORTB,0
cbi PORTB,0
rjmp loop
OK
reset:
down to 0x0f
out OSCCAL,r16
sbi DDRB.0
loop:
sbi PORTB,0
cbi PORTB,0
rjmp loop
Hvat does I wrong?
reset:
0x10 down to 0x0f
; out OSCCAL,r16
sbi DDRB.0
loop:
sbi PORTB,0
cbi PORTB,0
rjmp loop
..org 0x3fe
..db 0x80
HM
