Automotive alternator windings & rectifier
Discussion in 'Electronic Equipment' started by Mike Cook, Aug 19, 2013.
  1. Mike Cook
    Mike Cook Guest
    http://www.autoshop101.com/forms/alt_bwoh.pdf
    has photos of an alternator with 4 connections for windings (each of 3 phases
    + common), and the 8 diode rectifier. But wiring diagrams show only 3
    connections and 6 diodes.
    Where does the common winding terminal connect (there is a connection on the
    rectifier plate)? Where do the other 2 diodes connect?
    I handled one of these disassembled units but didn't have time to ohm out the
    connections.
    Thanks.
    #1
    1. Advertisements
  2. Mike Cook
    Jasen Betts Guest
    common to the chassis
    3 big diodes to battery positive
    3 small diodes to the altenator regulator
    another small diode between the regulator and the altenator light,
    eigth diode, dunno.
    Jasen Betts, Aug 20, 2013
    #2
    1. Advertisements
