ATX power supply to bench lab supply? help
AlenZGB
Feb 19, 2014
181
Feb 19, 2014
181
I could use some tips on how to convert PC power supply to bench lab supply.
i have some old 450w power supply, and my vision look something like this:
Convert power supply to max 24V(if it can`t be done since its older one. then 12v is ok) with variable potentiometer and voltmeter lcd.
So that i can use it to test/fried PIC that i manage to program, and for lots of other stuff.
Any ideas would be nice.
AlenZGB
Feb 19, 2014
181
Feb 19, 2014
181
I try that, but was wondering if anyone have done it already and do something other then google instructions.
Sadlercomfort
Ash
Feb 9, 2013
424
Feb 9, 2013
424
I've seen these tutorials, looks like a great idea. This guy looks like he knows what he's doing, nice quality to his work.
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
A lot of those power supplies have very little room to safely add additional connectors
My recommendation would be to get an appropriate "extension" for the power supply main connector then wire your terminals to that. This has the distinct advantage of allowing you to replace the power supply in the future if anything goes wrong.
AlenZGB
Feb 19, 2014
181
Feb 19, 2014
181
I come across this construction.
Just i want to do it without ammeter,only with voltmeter.
and one only ground and positive connector.
and potenciometer for regulation from 2v-24v
cover it with some tape, like sticky carpet, i still got it when i made my subwoofer box.
cover enough not to look like Bender from the futurama but leave holes for vents.
davenn
14,254
14,254
well you would need a boost convertor on either the 12V or 5V rail to boost it to approx. 26 to 28V
Then another adjustable regulator, as an example, say a LM338 ( 5A max ) to vary that 28V between 2 and 24V
ohhh and I wouldn't cover any of it with tape, they need all the ventilation they can get
if you want it to look nice, remove the board, fan and mains connector and mount it in a better looking case
that's to your liking
Rleo6965
Jan 22, 2012
585
Jan 22, 2012
585
I'm also in the process of building Lab Bench Power Supply from 300W ATX PSU. I'm going to use it for my Car Electronic projects that the reason I have to modify the PSU circuit to have dc output of +13.8V. I also include the the ATX dc out +3.3V, -12V & +12V for Opamp Supply. Planning to have Variable DC output +12V to 2.5V using LM317 w/ 2N3055.
Front panel casing was from defective PSU.
AlenZGB
Feb 19, 2014
181
Feb 19, 2014
181
Maybe i read it wrong but shouldnt i get 24V when i connect something on -12V and +12V?
But i wont get more then 3-4A or I read it wrong or the writer is wrong.
@davenn
Didnt ment all the ventilation to be covered, just metal parts that dont have ventilation points, it has 2 vents,
plus they wont turn on all the time, they should turn on only when needed, more consumption of power or am i wrong?
@Rleo6965
Looking good, i kinda like this analog thing, but i already ordered the digital ones.
davenn
14,254
14,254
you are not going to be able to use the +12 and - 12V rails like that as they don't have the same current capability
the -12V rail is usually very low current ... What is the rating for your -12V rail on YOUR PSU ?
and added to that ... most adjustable regulators need at least 2V headroom, which is why I said you need the 26 - 28V into the adj reg.
There may be some switching regulators that will work on 24V in and give ~ 2V - 24V. I haven't checked
something for you to do :)
cheers
Rleo6965
Jan 22, 2012
585
Jan 22, 2012
585
@Rleo6965
You can't use -12V and +12V to get +24V and its also low ampere.
Kiwi
have a better suggestion that you buy that DC to DC Converter and you connect it to the +12V with High Ampere capacity ( Yellow Wire ).
http://www.ebay.com/itm/DC-DC-Conve...6A-/261049815695?ssPageName=ADME:L:OU:US:3160
(*steve*)
25,510
25,510
Some (many?) modern PC power supplies have multiple 12V rails.
It is conceivable that you could take one of these and ground the positive side instead of the negative to get a high current -12V rail.
This is easy in principle, but probably much harder in practice. You'd have to mess with a large groundplane and possibly insulate rectifiers from the heatsink.
It would be a great hack though.
Solidus
Jun 19, 2011
349
Jun 19, 2011
349
Most PSUs that I know of at least do cursory isolation of much of their 12V supplies so that they are independent of one another. That's not to say each yellow/black wire is independent, but there are multiple supplies.
The CPU derives its supply (anywhere from 2.0V to 1.0875V depending on manufacturing process/generation) from the 12V lines (oddly enough, not the 5V lines) and in many cases, use three-phase bucking setups. The isolation, I believe, is for noise purposes, not only for other chipsets on the motherboard but to shield each bucking phase from another - these things have to be very efficient - if phase noise gets to the wrong places in a 40-75A output supply to the processor then you get a lot of heat where it shouldn't be.
AlenZGB
Feb 19, 2014
181
Feb 19, 2014
181
Looks like ill have to use booster from Ebay.
Just ordered one. Now the preparations for lab PS case.
thats some old P4 PSU. nothing special about it. Thats why i want it be gone and serve another purpose :D
@(*steve*)
Guess its harder in practice, seen that in my hot air station PCB repair :D
Kaboom style. i think ill look into it soon :D
