T
ted
We have been using The Philips version of ths chip for a while with no
problems. AS they don't seem to be made any more, we moved to the
Atmel equivalent (part number on the chip: 89C51RD2-IM)
However, we are having problems trying to program the Atmel chip using
the serial Intel hex ISP protocol. We never had any problems when
progamming the Philips part using the same programmer (a custom made
unit)
The only change we made was to reduce the programming voltage from
12volt to 5. The PSEN, ALE and EA lines are all exactl as required for
the Philips part.
The programming software when run seems to work OK, The echoed full
dot codes '.' are returned by the chip on every hex sequence sent as
they should. However, when attempting th read the contents of the chip
back, ROM locations 78 to 7F never seem to program correctly, they are
stuck at FFhex. We have tried a batch of five Atmel chips, they all do
exactly the same.
Are we doing something wrong? Are there any essential differences
ebtweeen the Philips programming method and the Atmel one that we
should be aware of??
Thanks in advance
Ted
unit)
the Philips part.
exactly the same.
Thanks in advance
Ted
