N
neo644
Hello, I'm using an Atmel ATmega8515 micro controler, and i have a
problem writing the fuse bits. I did write them, but i think i did it
wrong (I'm using an external crystal oscilator at 16MHz, with 15pF
capacitors), and now i can't reprogram the uc cause it wont oscilate,
thus the programmer (avrxs) doesn't recognize it. I've changed the
crystal for a 4MHz one but stil it wont start up. The avrxs reports
that there is a cable connected, but it doesn't recognize the device.
Is there a way to reset the fuse bits so it uses the internal
oscilator or something to solve this problem?
Thank you, Jony.
Thank you, Jony.
