D
Darren
Hi
My spare PC is in an AT case. It's currently powered by a 200w AT power
supply.
The motherboard has AT and ATX connectors. The mobo is an Epox EP-58
MVP3C-M and has power connectors for both AT and ATX cases.
I'm taking out the generic AT 200w power supply as it's getting old and I
have a new 400w ATX power supply to put in.
The AT PSU has a power cord which runs to a button on the front of the case.
The ATX PSU does not have a power cord with a button attached to it.
I've noticed the mobo has a 2 pin connector labelled 'POWER-ON'.
After installing the new ATX PSU, is it a case of buying a power button with
two wires that go to the 2 pin 'POWER-ON' connector?
If so, I'm not sure which pin will be positive and which will be negative
and I'm not sure my mobo manual tells me...
I suppose that electronics shops would stock these buttons.
I'm from downunder, if that helps with PC component location advice.
Thanks heaps
Darren
supply.
Thanks heaps
Darren
