Aquarium lights and fan
Discussion in 'LEDs and Optoelectronics' started by enli, Jan 6, 2017.
  1. enli
    enli
    Jan 14, 2016
    9
    Two lights that are each on a separate switch, black & white wires for each light. One fan, black and white wires. Fan is wired to come on when switch for light #1 is turned on. Light #2 switch only turns on light. Is it possible to rewire fan to come on with either light and with both lights on? It is desired that fan is on if either light is on and also if both lights are on. Switches have only two connection points per switch. Just don't seem to be able to get me head around this without buying new switches that would have 3 way capabilities. Thanks, Enli
    enli, Jan 6, 2017
    #1
    1. Advertisements
  2. enli
    Bluejets
    Oct 5, 2014
    2,434
    474
    DC or AC..?
    low voltage or mains supply..?
    3 way switch..?? think you mean 3 pole switch....either way a 2 pole single throw on each would do BUT it depends on the above..
    Bluejets, Jan 6, 2017
    #2
    1. Advertisements
  3. enli
    enli
    Jan 14, 2016
    9
    It's all 110ac, switches actually control the ballast for lights and the fan circuit goes to transformer that lowers voltage to 12v for small fans. Two incoming 110v power circuits are available, or could use a single power circuit. Lights are 18watts each and fan is small 12Volt-2/10s (.2) amps
    enli, Jan 7, 2017
    #3
  4. enli
    Bluejets
    Oct 5, 2014
    2,434
    474
    2 options .................
      File size:
      110.1 KB
      55
    Bluejets, Jan 7, 2017
    #4
    hevans1944 likes this.
  5. enli
    enli
    Jan 14, 2016
    9
    Thanks BJ, switches in top diagram would be double pole, single throw? What type of relays would I need for 2nd diagram?
    enli, Jan 7, 2017
    #5
    1. Advertisements
