The following is the output for a typical
session between the Fedora box and Raspberry
Pi.
ssh
[email protected] -vvv
OpenSSH_5.5p1, OpenSSL 1.0.0e-fips 6 Sep 2011
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Applying options for *
debug2: ssh_connect: needpriv 0
debug1: Connecting to 192.168.1.2 [192.168.1.2] port 22.
debug1: Connection established.
debug1: identity file /home/lama/.ssh/id_rsa type -1
debug1: identity file /home/lama/.ssh/id_rsa-cert type -1
debug3: Not a RSA1 key file /home/lama/.ssh/id_dsa.
debug2: key_type_from_name: unknown key type '-----BEGIN'
debug3: key_read: missing keytype
debug2: key_type_from_name: unknown key type 'Proc-Type:'
debug2: key_type_from_name: unknown key type 'DEK-Info:'
debug3: key_read: missing whitespace
debug2: key_type_from_name: unknown key type '-----END'
debug1: identity file /home/lama/.ssh/id_dsa type 2
debug1: identity file /home/lama/.ssh/id_dsa-cert type -1
debug1: Remote protocol version 2.0, remote software version OpenSSH_5.5
debug1: match: OpenSSH_5.5 pat OpenSSH*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_5.5
debug2: fd 3 setting O_NONBLOCK
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
[email protected],
[email protected],ssh-rsa,ssh-dss
debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,
[email protected]
[email protected]
debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,
[email protected],hmac-ripemd160,
[email protected],hmac-sha1-96,hmac-md5-96
debug2: kex_parse_kexinit: none,
[email protected],zlib
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: kex_parse_kexinit: ssh-rsa,ssh-dss
[email protected]
[email protected]
[email protected]
[email protected]
debug2: mac_setup: found hmac-md5
debug1: kex: server->client aes128-ctr hmac-md5 none
debug1: kex: client->server aes128-ctr hmac-md5 none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<1024<8192) sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
debug2: dh_gen_key: priv key bits set: 124/256
debug2: bits set: 513/1024
debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
debug3: check_host_in_hostfile: host 192.168.1.2 filename /home/lama/.ssh/known_hosts
debug3: check_host_in_hostfile: match line 1
debug1: Host '192.168.1.2' is known and matches the RSA host key.
debug1: Found key in /home/lama/.ssh/known_hosts:1
debug2: bits set: 567/1024
debug1: ssh_rsa_verify: signature correct
debug2: kex_derive_keys
debug2: set_newkeys: mode 1
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug2: set_newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug1: Roaming not allowed by server
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug2: key: /home/lama/.ssh/id_dsa (0x1996038)
debug2: key: /home/lama/.ssh/id_rsa ((nil))
debug1: Authentications that can continue: publickey,password
debug3: start over, passed a different list publickey,password
debug3: preferred publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Offering public key: /home/lama/.ssh/id_dsa
debug3: send_pubkey_test
debug2: we sent a publickey packet, wait for reply
debug1: Trying private key: /home/lama/.ssh/id_rsa
debug3: no such identity: /home/lama/.ssh/id_rsa
debug2: we did not send a packet, disable method
debug3: authmethod_lookup password
debug3: remaining preferred: ,password
debug3: authmethod_is_enabled password
debug1: Next authentication method: password
[email protected]'s password:
debug3: packet_send2: adding 64 (len 57 padlen 7 extra_pad 64)
debug2: we sent a password packet, wait for reply
Permission denied, please try again.
debug1: No more authentication methods to try.
Permission denied (publickey,password).
