W
Watson A.Name - Watt Sun, Dark Remover
I got to thinking about all these projects I've built in Altoids tins,
etc. One drawback is that they aren't waterproof, or water resistant.
They pretty much let the water in, even in the rain.
I've built a couple of them in an 'open frame', in other words, on a
piece of flat aluminum, or in an L shaped piece of aluminum. They're
sturdy, and work okay. They are totally open to the elements, so
water would go ritght into them.
But then I got to thinking. Is that a problem? The batteries,
circuit and LEDs wouldn't be hurt by a little water if it dries out in
a short period, which is what happens with the open frame. About the
only thing that would corrode a lot would be the switch, because it's
enclosed and the water would gather inside and stay there, rusting the
contacts and other moving parts. I guess I could pack some grease
into the switch, to help keep out the water. But I found that one
cheap flashlight I bought wouldn't turn off, the LEDs would continue
to glow. Well, apparently the grease in the switch was conducting a
bit, causing the LEDs to stay on very dimly. So I'd have to use some
non-conductive grease.
BTW, I'm presuming that the water is like rain water, not water with
salt in it like seawater. Seawater would corrode anything since he
salt would stay there after it dried and humidity would keep it
corroding, unless everything was either stainless steel or bronze.
But I'm not concerned about salt water, only regular rain water.
Just looking for thoughts on this idea.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
