How can I check if I have chip for 5 volts for usb otg inside my anroid?
P Pavle Sep 21, 2015 56 Joined Sep 21, 2015 Messages 56 May 19, 2016 #1 How can I check if I have chip for 5 volts for usb otg inside my anroid?
Gryd3 Jun 25, 2014 4,098 Joined Jun 25, 2014 Messages 4,098 May 19, 2016 #2 Pavle said: How can I check if I have chip for 5 volts for usb otg inside my anroid? Click to expand... You look at the specifications for your device... it should say if it's OTG compliant... Otherwise, buy an OTG adaptor and plug something in
P Pavle Sep 21, 2015 56 Joined Sep 21, 2015 Messages 56 May 19, 2016 #3 My phone supports otg,I have otg cable,but when I connect flash drive or any other usb device I don't have power on usb port,
Gryd3 Jun 25, 2014 4,098 Joined Jun 25, 2014 Messages 4,098 May 19, 2016 #4 Pavle said: My phone supports otg,I have otg cable,but when I connect flash drive or any other usb device I don't have power on usb port, Click to expand... What is 'other' usb device? What is the model of your phone? Please keep in mind that OTG is a newer feature and supported output currents may be quite low
