Jeff Pelletier
I've been trying to assemble an analog VU meter to hook up to a VCR.
I've got an analog panel VU meter, a bridge rectifier, and very little
knowledge of electronics.
I figured the easiest way to wire this, would be to splice the end of
an RCA cable. I've assumed that the shielded wire in the center is
positive. The bridge rectifier I have has four diodes (?) sticking
out, only one of which is labeled +. This one is slightly longer;
there's two the same length, and one very slightly shorter than the
rest. From what I've read the shortest should be the positive input
which would make the longer one marked + the output to the VU meter...
No matter what configuration I use, I dont get any readings
whatsoever. I could very well be wayyy off on my understanding of this
thing.
Jeff
thing.
Jeff
