K
kell
My 1989 Jeep Cherokee started having an intermittent problem where it
dies sometimes when I'm driving and is getting harder to start..
After reading this page:
http://www.lunghd.com/Tech_Articles/Engine/Basic_Sensors_Diagnostics.htm
I tested the crank position sensor (cps) with a voltmeter. It showed
about .4 volts ac or a little less when cranking. That's below the
acceptable voltage range of .5 to .8 volts stated in the article.
The cps is on the bell housing, very difficult to get to. It's
recommended that you lower the transmission a little. You need a
floor jack, which I don't have.
I got the idea of building a circuit to amplify the signal from the
cps.
Some basic facts... there are only two wires coming from the cps.
With the car turned off, the cps is supposed to measure about 275 ohms
(mine measures 230). As I indicated before, the cps generates a small
signal (detectable with a voltmeter set on ac) when the flywheel is
turning and the slots are flying past the sensor.
While I had the connector unplugged, I also tested the pins on the
wiring harness side of the plug. With the ignition key turned on both
pins show 3.37 volts with respect to ground and zero volts across the
pins.
I need some kind of fix, even a temporary one, just to get the car
running. I park on the street and have to move it periodically.
I thought of using a non-inverting op amp circuit, powering it
independently (just a couple of nine volt batteries for now) because
I'm not sure how it would work using the vehicle's electrical system
to supply the power. Can you use a single supply if the op amp is
amplifying a small ac voltage several volts above ground? There
wouldn't really be a fixed ground for the op amp to refer to.
cps.
pins.
