LearningSomethingToday
- Mar 4, 2018
- 23
- Joined
- Mar 4, 2018
- Messages
- 23
I am working on an amp that has 8 output transistors per channel. The 8 output devices are on two separate heat sinks with two complimentary pairs on each heat sink. The two heat sinks are tightly sandwiched to form a single channel module. The amp has two of these sandwiches to form a stereo pair. One of the sandwiches has a heat problem.
I have one of the four heat sink halves getting uncomfortably warm. All the output devices on that heat sink test ok with a meter. The two heatsinks for each module only have thermal feedback on one half. The half that is getting warm has no feedback and I feel will eventually go into thermal runaway.
There is a 1 ohm, 5 watt ceramic resistor on each output transistor. I wanted to see what was occurring across each of these resistors and I get readings all over the place. I read 15mv, 15mv, 53mv, 15mv across the resistors on one half heat sink and 9mv, 56mv, 9mv, 50mv on the other.
I am assuming this would be the bias voltages. Shouldn't these numbers be in close proximity to each other?
From anothers perspective, what am I looking at here?
This amp does have a DC balance adjustment but does not have a bias adjustment. It uses a thermal compensator to adjust bias. I would think that the compensator would make all the output devices read similar bias voltages so I am scrathing my head.
