M
Mike Wilson
Hello there
Love the site! Anyhoo, I need help with my amp. I have a old Kenwood amp. I
think it was manufactured around 1988, 120W, 4 or 8 Ohm rated. A few years
ago (when I knew little about electronics) I had the amp serviced, one cap
and 2 voltage regulators where replaced. The one cap that was replaced is a
large, 42v 6800microferret cap (3 leads bottom of cap). The amp has been
running fine for years. Recently, the woofers start pulsing when the volume
is turn down low and the bass is about half way. If the volume is turned up
to about half way, the problem stops. This pulsing will happen with or
without playing any music. The pulsing only happens in the bass (woofers).
The pulsing does go away when one speaker is removed.
When testing the amp, no speakers attached, I used a volt meter set to 200
ma to see if there is any voltage leaking to the speakers, yep sure enough,
there is about 40ma leaking. Next I tried the two large caps that are near
the power supply. One is a 63v 6800 microferret and the other is a 42v 6800
microferret. with the amp turned on, both caps charge up to their respective
voltages. When the amp is turned off, the voltage in both caps are gone in
about 2 seconds and only a slight charge is left over, around 140 ma
Shouldn't the caps hold a charge, is this normal? Next I decided to take one
of the suspected caps off of the board. Charged it up with a 12v power
source, when I tested it, the reading dropped from 12v to less than a volt
in a matter of a second, is this normal for a 42v 6800 microferret cap?
Please help as I cannot seem to figure out why the amp is doing this!!!!!!
Thanks in advance
Mike
Thanks in advance
Mike
