L
Lord-Data
What principles are used behind a GOOD airhockey table?
I know you can get cheapy ones that have air but not much else.. More
interested in the scoring side of things .. Whats a reliable way to detect a
puck entry? Optical sounds dodgy, but so does press switches, too easy to
not trip .. given the angles and different speeds the puck could come in at
Anyone know what the arcade machines use? Also, for the air system, what
kind of system runs it? Never hear much of a pump/compressor noise from the
arcade machines, so i'm guessing somethign small suffices there? Anyone know
much about the sytsems used? Is it just a pump sealed into channels in a
base, with a top overlaid with holes drilled through?
Thanks in advance for any info you can provide!
