F
Father Jack
Hi there,
I have a problem with a 10 year old Ademco Vista 4110 Alarm Control as
follows:
Keypad keeps intermittently showing no AC. I've checked for faults on
all related Circuits (found none), fitted a new system battery but the
fault still exists. The System can not be set when the No AC fault is
showing but works as it should if you can key in the code quickly
enough between fault on and off indication. Honeywell Technical just
don't want to know. My question was - Is there a hidden field in the
software that would allow alarm to set with no AC power? At this
moment in time I've left the customer with the quick set option
programmed on & this seems to do the trick. Any suggestions or advice
would be most welcome as this customer lives on her own and is a
Senior Citizen! Hence can't afford a new Panel & Keypad!
Kind Regards
follows:
Kind Regards
