motorcycle accessories are all the rave....
so here is my final workup on the overpower tail light problem I have created for myself...
Alternator puts out 14v 20amps @ 5000rpm to charge a 12v/20ah battery
if I run an accessory of 5 - 27.5w bulbs, which totals to 137.5watts
My alternator puts out 280watts at 5000 rpm....
but I have a 4 amp regulator, which reduces the power capability substantially--
280w / 4a = 70v which is about 68v short of what I need.
assuming this same equasion with the actual watts instead of alternator watts at 5000rpm
137.5w / 4a = 34.375v still way too high.
inventory-
60w headlamp
8w x2 = 16w tail
27w x2 = 64w brakes (intermittent mostly off)
27w x 4 = 108w signals(intermittent mostly off, 64w normal max flash)
3.8 x2 = 72w plate light
control board
3.4w x9 = 30.6w indicators
8w x2 =16w running lights
366.6w total standard wattage
137.5w of accessories
504.1w required
a 20ah, 12v battery delivers 240watts.
504.1w required - 240w available = 264.1w
because 264.1w is larger than 240w
we could say we have a 504.1w drain of 24.1w
We can't build a speciallized 504.1w system, because we are using 24.1w too many...
because the system has intermittent usage of the turn signals and the brake lights and the control board,
the system is working ok.... but it can't deliver the 4a that is nessesary to charge the battery
24.1w / 12v = 2amps
So if I can create a direct input generator that delivers 2amps into my fancy accesory it should allow the regulator to charge the battery... as it is, the regulator is taxed 2amps by the accessory, leaving only 2amps of charging power to charge the battery...
THE BATTERY SULFATED AND DIED!
so I would need to isolate the original system, make a secondary set of controls-add a battery-and generate 137.5w @12v
and the 11.46a that this produces could trickle spare charging power in, if needed. Like 20ma for 16hrs with a drain shunt to the main battery when the engine is off. caveat- the battery that I add will have to be larger than the one the system already has in it.
Whoo whoo was that a train?
inventory-
60w headlamp
8w x2 = 16w tail
control board
504.1w required
24.1w / 12v = 2amps
