ADC Hold and Sample
Hoobbyy_Engineer
May 21, 2017
13
May 21, 2017
13
Hello Everyone,
Do all microcontroller ADC implement hold and sample circuitry internally?Or should I have to provide it externally?
Regards,
Nil
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
No -- not really. Yes, possibly.
But it's far better to read the specs of the micro-controller that you're using to make sure.
An ATMEGA 328, for example has an input capacitance (14pF from memory) that is allowed to charge for 2 clock cycles (again, from memory) prior to it being read. If the signal is expected to vary significantly within this 2 clock cycle period, then for best accuracy you'll need an external sample and hold.
Hoobbyy_Engineer
May 21, 2017
13
May 21, 2017
13
So the correct parameter to find this charging time for the capacitor is Acquisition Time,right?
(*steve*)
25,510
25,510
That's one important one.
If you're using atmel chips, check out the Avr127 application note. Even if you're not it still may be helpful.
