Actual experiences mod'ing laptop bricks?
Discussion in 'Electronic Design' started by Don Y, Jan 8, 2014.
  1. Don Y
    Don Y Guest
    I've got a ~200W laptop brick on which I'd like to tweek the
    output voltage (~5% -- 19.5V down to 18.5V). Anyone know what
    sort of margins they design into these? I'm not keen on risking
    the laptop for the sake of a $10 power supply... (i.e., "it
    *should* work" is not an acceptable reply :> )
    Thx,
    --don
    Don Y, Jan 8, 2014
    #1
    1. Advertisements
  2. Don Y
    mike Guest
    I use laptop power supplies for all kinds of stuff.
    Just change the sense resistor value.
    Changing 5% shouldn't be a problem.
    But the answer to your concern is in the risk/reward ratio.
    If you can get the right one for $10 and your laptop
    is worth much more than $10, it's a no-brainer.
    You might get better help if you listed more detail
    on what/why you're doing it?
    At that power level, there might be negotiation between
    the laptop and the brick.
    I've seen some power supply interface designs that I'd
    classify as stupid.
    My experience with sourcing custom OEM power supplies is
    that they're like everybody else...half of them
    are below average. And average ain't nearly good enough.
    So asking them ain't gonna be helpful either.
    mike, Jan 8, 2014
    #2
    1. Advertisements
  3. Don Y
    Don Y Guest
    Hi Mike,
    That was my plan -- but, I'm concerned with the downside
    risk (derating plus any "smarts" in the power supply that
    might be "confused" because they are unaware of this change)
    Not my laptop. These are laptops that were donated (without
    power supplies... sheesh!), will be "refurbished" and "gifted"
    to disadvantaged kids. (I.e., the sorts of folks who can least
    afford to bear the consequences for a bad decision on my part!)
    I can get my hands on a supply of these larger 200W supplies
    (virtually) "free" but am hesitant to *use* them "as is"
    (not knowing how tolerant the laptop is of variations in input
    voltage *above* spec). So, it's basically just my (donated)
    time to make the changes.
    OTOH, if I have to purchase power supplies (even "used"), they're
    in the $20+ range, each. (assuming I can find a single source
    at that price!)
    See above.
    Exactly. And, I'm sure any "smarts" therein won't take into
    account an *observation* of any component changes that have been
    made "post production" :<
    I know some of these power supplies refuse to work on "competitor's"
    products (despite having the same V+I characteristics)
    This is one reason why I want to avoid the "off brand"
    replacement products. So, I'm stuck with either "name brand"
    *new*... or *used*.
    Don Y, Jan 8, 2014
    #3
  4. Don Y
    dp Guest
    Hi Don,
    some years ago I tried this on a small 15V (IIRC) adaptor. It was
    somewhat smaller, not an ordinary laptop one but I got it because
    it stated its output was settable. It was not so I opened it hoping
    to find the feedback divider and change it (it was a cheap DX box).
    Turned out the designer had been pretty good and had done things
    not that obvious without having the circuit. The feedback was somewhat
    hard to modify, a "zener" (TL431) serially feeding current into
    the feedback optocoupler - and there was more to it than that
    which would have taken hours to understand so I just abandoned
    the idea (got another brick).
    I suppose there are many different designs out there and most of
    them likely (the one I abandoned unchanged included) allow a small change
    like the one you need but I think your only reasonable option is
    to open the thing and see for yourself. May be you'll know what to
    do within a few minutes, may be you'll give it up as impractical.
    Opening may not necessarily be easy; recently I had to cut the
    plastic of my laptops brick in order to open it to fix the outgoing
    cable....
    Dimiter
    dp, Jan 8, 2014
    #4
  5. Don Y
    Don Y Guest
    Hi Dimiter,
    Happy New Year!
    The adapter is rather large -- probably 20+ cu in. Hopefully, not
    as cramped as some of the tinier beasts out there.
    And, as it's so large (power), I suspect (?) it may be a bit
    better designed than the "500mA disposables".
    My main concern is no knowledge of the information that is exchanged
    (one way? two way? *interactive*??) between the adapter and the
    laptop.
    I.e., at the very least, the laptop will know that this is a "native"
    adapter (same manufacturer) vs. a "foreign" one. Will it know which
    *model* adapter? Will it only be willing to operate with *known*
    models (BIOS update)?
    Will it *command* the adapter to "switch to normal output voltage"
    (perhaps it is initially in a low voltage mode that enables the
    two devices to converse without putting either in jeopardy)?
    Will it query the adapter dynamically to determine current operating
    conditions?
    If there are smarts in the adapter, will it notice that Vout is not
    what it *should* be? Will it try to compensate? etc.
    (once you open the door for smarts *in* the power supply, it no
    longer is a "trivial component")
    I'm not keen on discovering these issues via "smoke signals"!
    (they aren't my laptops to "destroy")
    --don
    Don Y, Jan 8, 2014
    #5
  6. Don Y
    dp Guest
    I have not seen that many laptops but those I have seen don't have
    such a thing, just a plain two wire connection. These I have opened
    have been far from suggesting the cable could be carrying anything
    else but power. I'd be very surprised to see such a thing.
    Again, I have not seen this done but then I am far from having seen
    them all... If you dedicate a day's work on opening the laptop
    and investigating (oops, just opening might take you a day...
    I remember opening one for cleaning the air path 1-2 years ago,
    took me hours).
    I have bought 3-4 type of different "laptop chargers" from DX
    (to use on anything but laptops, that is) and none of them had
    any indications of such a thing (and I have opened... let me see,
    I think 4 if not 5 types, one really old, all models would be older
    than say 3 years, may be more).
    Dimiter
    dp, Jan 8, 2014
    #6
  7. Don Y
    Don Y Guest
    Hi Dimiter,
    These have a third connector that carries *some* sort of a signal.
    E.g., if I take a power supply from HP and try to plug it into a
    Dell laptop (same Vout, Imax, connector dimensions) the Dell laptop
    will complain. Most typically, it will refuse to charge the
    battery (or, will not charge it completely, etc.)
    The two conductor power supplies are admittedly dumb. Easy to
    repurpose a power adapter from vendor A for vendor B's equipment
    (as long as V & I are compatible and you can get an appropriate
    connector on the end).
    I've done this many times in the past. E.g., one of our TV's is
    powered by a laptop power supply (because the original power supply
    died).
    Don Y, Jan 8, 2014
    #7
  8. Don Y
    Don Y Guest
    Don Y, Jan 8, 2014
    #8
  9. Don Y
    dp Guest
    Oh so some have started to put some I2C eeprom or whatever to make
    people buy exactly their charger. The laptops I have been buying
    are Acer, no such thing. Why should I be surprised really. I think
    I have seen a Sony which did not have that sort of thing either
    but I am not so sure about that.
    If you have one of these laptops with "encrypted" power I don't think
    you have many options but to pay them up (likely around $100 rather
    than $10...).
    One more thing to watch for when buying, one could easily overlook it
    I guess.
    Dimiter
    dp, Jan 8, 2014
    #9
  10. Don Y
    Jasen Betts Guest
    If ~188W output is acceptable at 18.5V tweaking the voltage should be
    possible with no ill effects.
    (in other words same maximum DC output current)
    Typically switchers use a slosed loop matching a (resistive) voltage
    divider off the output against a fixed reference, you just need to
    find the divider and tweak the ratio.
    measure it and test it on a dummy load before connecting the laptop.
    Jasen Betts, Jan 8, 2014
    #10
  11. Don Y
    Tim Williams Guest
    I would be surprised if the laptop cared; most are probably good from
    16-25V. Inspecting a few laptop motherboards, it looks like there's a "HV
    / bulk" supply from which all the others are derived; some battery
    management circuitry selects the battery or charger (the adapter of course
    being higher in voltage so a sync buck and battery controller handle the
    actual charging). 14.4V batteries are common (four cells in series, plus
    however many in parallel), and so are 18-19V chargers.
    Of course, if "probably" isn't good enough, trimming resistors will be in
    your future. :)
    Assuming it's a flyback supply, the lower limit will be due to UVLO on the
    probably UC3842 controller, supplied by the aux (line side) winding. Once
    you crack it open, you could probe the controller or the little
    electrolytic in there to see what it runs at, and from there, figure it
    can go as low as the turnoff limit. Any lower and it'll always bob on and
    off, which is obviously bad. But that's probably 30% lower than you need.
    Tim
    Tim Williams, Jan 8, 2014
    #11
  12. Don Y
    dp Guest
    I would expect to see something like that, too. At least this is how I
    did it on the nukeman (design 1993, http://tgi-sci.com/tgi/fr64.gif ,
    then around 2000 http://tgi-sci.com/tgi/pntb.htm ).
    Basically all convertors were powered off the battery voltage which
    was 9 NiMH in series. I had put an overvoltage limit to the charger
    stepdown which limited that voltage to about 15 (or was it 15.5)V;
    in case of no battery etc., I had opamps powered powered off that
    voltage which would not survive over 15.5 (lmc6482).
    But the input voltage range was not that generous, I had used a
    PMOSFET as the charger stepdown switch and its gate was driven by
    an MC33151; which was powered from the adaptor directly, I think
    it would not survive anything above 20V. Not so sure how things
    were really. I remember I did burn a few 33151s until I got things
    to work OK though :).
    Anyway, Don's issue is with the "smart" part of the adaptor, which
    has little to do with voltages.
    Dimiter
    dp, Jan 8, 2014
    #12
  13. Don Y
    Don Y Guest
    Hi Dimiter,
    That's the case for the example I *showed* you. But, I2C can easily
    allow more than "identification" to reside in the power supply!
    You could just as easily put an MCU in there that monitors voltages,
    gates the output on/off, etc.
    I.e., the power supply can now become an *integrated* part of the
    laptop instead of just some "external voltage source".
    In my case, the concern is whether a *different* power supply
    (by the same manufacturer as the "ideal" power supply) would
    "behave" when connected to the laptop.
    The laptop could decide not to recognize the power supply
    ("wrong ID"). Or, some feature may become unavailable
    (e.g., battery charging seems to be the most common one).
    Or, something even more nefarious (e.g., if the power supply
    is "actively smart")
    Yup. I've seen "universal power supplies" with assortments of
    interchangeable "connectors" (and adjustable Vout). Even those
    including these "three pin" connectors. But, if they don't
    know how to identify themselves as the appropriate *actual*
    power supply, then what good are they?
    Don Y, Jan 8, 2014
    #13
  14. Don Y
    Don Y Guest
    Hi Jasen,
    That would depend on the actual topology used. For a trivial
    example, imagine a *linear* where the change would result in
    an extra ~10W going up as heat at that same output current.
    Measure *what*? Vout is a no brainer. But, how do I know
    something inside the supply isn't operating closer to its
    limits?
    Remember, this is consumer kit. Everything seems to pride itself
    on how close to the edge it can be designed *and* how few days
    beyond warranty it can survive!
    The same mentality that saves fractional cents on caps is at play, here.
    Don Y, Jan 8, 2014
    #14
  15. Don Y
    Don Y Guest
    Hi Dimiter,
    I'm concerned about the entire "subsystem" -- as the power supplies
    are obviously moving beyond "dumb voltage sources" to more of an
    "integrated system". When you start integrating things, you tend
    to use them (and design them) in ways that leverage other aspects
    of the system to improve their performance, decrease their cost
    or provide added functionality.
    It seems like there is little value to encoding *just* an "ID"
    in a power supply. AFAICT, you can't make your initial purchase
    (of the laptop) without getting a power supply in the deal. So,
    the ID only protects sales of *replacement* power supplies.
    [It also could give some liability protection if third party
    power supplies are resulting in battery fires, etc. "Due diligence"]
    Is there a big problem with folks *losing* their power supplies?
    Or, are there plans to artificially grow the power supply market
    with a move to even crappier designs/reliability??
    It looks like the safer approach, for me, is to find a deal on
    the "Right" power supplies (buying them by the dozen can help).
    Or, convince a donor to foot the bill for them...
    (though it would be an interesting question to have answered!)
    Don Y, Jan 8, 2014
    #15
  16. Den onsdag den 8. januar 2014 21.30.54 UTC+1 skrev Don Y:
    most laptop chargers have a similar barrel connector, only the voltage and power varies all the smarts are in the laptop
    and you can get universal car adaptors that just a buck/boost to set the
    right voltage and a set of connectors
    There's an effort to standardize laptop chargers, similar I guess to how EU mandated that cell phones must be able to charge from USB
    -Lasse
    Lasse Langwadt Christensen, Jan 9, 2014
    #16
  17. Don Y
    Greegor Guest
    If the idiotic little ID chips are doing nothing
    but ID, then wouldn't it be easier to modify the
    BIOS code on the laptop so that it doesn't care
    about the ID code? The BIOS is flashable, right?
    Greegor, Jan 9, 2014
    #17
  18. Don Y
    Don Y Guest
    Hi Lasse,
    That's not the case with these. *Three* conductors. The third of which
    carries "data" from (to?) the charger. At the very least, the laptop
    can say, "This is not an approved (i.e., sold by me) power adaptor.
    I refuse to ___________"
    As seen in the URL I posted (elsewhere) for Dimiter, at least one
    such adapter has a ROM inside that the laptop queries. Presumably,
    if the ROM is absent or contains "funky" data, the laptop could opt
    not to perform (or, perform incorrectly).
    It's unclear if other power supplies (including the ones in
    question) do anything *active* with the comm link (e.g., transfer
    information about the temperature of the power supply, load current,
    etc.). Or, if the laptop *commands* the power supply ("enable
    charging mode") during operation.
    Different beast.
    The fact that vendors (at least IBM, Dell and HP, from my experience)
    are adding this "feature" to their power adaptors suggests they
    want to hold onto the power adapter business (?). Note you don't
    see much effort to standardize ink jet cartridges :> Nor do
    I imagine any printer vendors will be quick to embrace such an idea!
    Don Y, Jan 9, 2014
    #18
  19. Don Y
    Ralph Barone Guest
    About the only good reason I can think of to have the power supply "talk"
    to the laptop is to allow different battery charge rates for different
    sized chargers, therefore allowing the manufacturer to sell either a big
    "home" charger or a small "road" charger and have the laptop charge as fast
    as possible with either one.
    Ralph Barone, Jan 9, 2014
    #19
  20. Don Y
    Don Y Guest
    Hi Ralph,
    I can imagine a power supply "telling" the laptop that it (the power
    supply) is running hot and, thus, should reduce its load (esp given
    that the laptop has control over a *big* piece of its load -- the
    charger!).
    I can also imagine a power supply telling the laptop how much power
    it is *actually* using (adding those monitoring components *outside*
    the physical constraints of the laptop itself) so the laptop can
    better calibrate its battery monitoring algorithms (instead of
    just watching Vbat without any real idea as to how quickly it
    *should* be falling -- when operating on battery).
    And, the mere presence of a third conductor could be exploited to
    *move* the charger into the power adapter using the third conductor
    to deliver "charge current" separate from "operating power" for the
    laptop. Even potentially multiplexing (TDM) data onto that conductor!
    As I said, once you open the door to smarts in the power supply, you
    can come up with lots of more interesting designs with increased
    levels of integration across the "power cord" boundary!
    [But, other than the URL I posted suggesting "ID" information,
    I have no idea how power supplies currently use the conductor]
    Don Y, Jan 9, 2014
    #20
    1. Advertisements
