Activating door video phone with normal bell push.
Discussion in 'General Electronics Discussion' started by Ashish Vohra, Sep 13, 2018.
  1. Ashish Vohra
    Ashish Vohra
    Sep 13, 2018
    I have a door video phone installed outside my door, adjacent to the normal doorbell switch. I need to be able to combine the functionality of both the devices by pressing just the doorbell switch. The idea is to use some kind of a relay (preferably solid state) that gets activated when doorbell switch is pressed, and that in turn, closes the video phone switch, while both the circuits stay electrically insulated from each other.
    The video phone is Samsung make and works on a 12 volt DC supply, while the doorbell is a standard 230 volt ding dong type (not the electronic one).
    Requesting members for help in suggesting the exact relay that may be used, or if it is to be used in conjunction with some other components, and the schematic of the circuit.
    Thanks in advance.
    #1
    1. Advertisements
  2. Ashish Vohra
    ramussons
    Jun 10, 2014
    331
    61
    ramussons, Sep 14, 2018
    #2
    1. Advertisements
  3. Ashish Vohra
    Ashish Vohra
    Sep 13, 2018
    Thanks for the prompt response. Could you kindly suggest if there is any solid state relay that can be used here? Thanks.
    Ashish Vohra, Sep 15, 2018
    #3
  4. Ashish Vohra
    ramussons
    Jun 10, 2014
    331
    61
    Yes, they are available. Have you thought of using opto coupled Triacs? They form a sort of SSR.
    ramussons, Sep 17, 2018 at 2:02 PM
    #4
    1. Advertisements
