A little progress made
I
Ignoramus14534
I fully redid the timing operation of my microcontroller. Now it wakes
up every 1/10 second and records a time tick, and based on that I keep
track of time hours/minutes/seconds since start, and also of elapsed
time. I use elapsed time for preflow/postflow and such.
(wen I say wakes up, I must clarify that it does not sleep, it keeps
running the main loop, but it interrupts itself with a timer interrupt
evey 0.1 sec)
As always, the source code is released under GPL and is here
http://igor.chudov.com/projects/Welding/11-New-Rectifier/source.txt
i
R
Rich Grise
evey 0.1 sec)
And you've got the watchdog reset in the main loop, not in an interrupt
handler, right?
Cheers!
Rich
I
Ignoramus14534
handler, right?
Rich, what watchdog?
i
B
Boris Mohar
evey 0.1 sec)
I was using my Lincoln 175 TIG and rapidly running out of Argon. This was a
part of convoluted SS exhaust manifold that I am nearing the completion of.
One moment I would be tacking thin bits being careful not to burn through and
next moment I would be using some serious current. This made me think of you
project and the following issue. My Lincoln has postflow of 15 sec which his
hard wired. Very irritating when the main gage is reading zero and I was
tempted to aim the arc at the Argon tank to squeeze out some more gas.
You have a programmable controller. You know how much current is flowing and
for how long it has been flowing. It would not take to much coding to come
up with postflow based on those parameters. Another nicety would be to be
able to adjust the flow based on current. Can your microcontroller
incorporate a flow controller?
Regards,
Boris Mohar
Got Knock? - see:
Viatrack Printed Circuit Designs (among other things) http://www.viatrack.ca
void _-void-_ in the obvious place
I
Ignoramus14534
hard wired.
You hit the proverbial nail on the head. Yes, it can incorporate
variable postflow and I will. It is not hard to figure out how to do
postflow. (same exponential moving average of current)
I wanted to put it in my welder ASAP, now I realized that this haste
is harmful. I want it to spend time on my bench, I want to wire PWM
based outputs to control welder's voltage and current, I want to
program variable postflow, pulsed TIG, etc etc. It is better if I
spend one extra week programming on the bench, it is easier than
standing in front of the welder with my laptop in my garage.
You can see my source code at
it changes all the time. This is the CVS copy of my source code.
i
