74HC390 table of pin connections?
Gillie
Apr 14, 2017
13
Apr 14, 2017
13
Hello
First question here. I want to experiment with 74HC390 chip. I know the pin strappings for divide by 4 (example (14 to 2), (15 to 3), (2,4,8,12,14 to Ground), 1 in and 13 out) and divide by 100 from a Mr Carlson's Lab YouTube clip, but I would like to find the pin strappings for the other possibilities (I believe I could divide by 2,5,10,20,25,50?). Someone must have produced a table, but extensive Googling fails to find it!
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
Did you look at the datasheet of the SN74HC390? Oh, Texas Instruments say it is obsolete do not show its datasheet.
Gillie
Apr 14, 2017
13
Apr 14, 2017
13
Thanks for the speedy reply! Unfortunately, I cannot glean the info I need from the datasheets.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,886
Jun 21, 2012
4,886
Well, actually you can if you understand how the counters work. Review this Texas Instruments datasheet for this obsolete and no longer manufactured part. Then breadboard a trial circuit using a low-speed clock, typically a de-bounced push-button switch, and a logic probe to see what is going on.
Herschel Peeler
Feb 21, 2016
401
Feb 21, 2016
401
Hello
See attached pdf.
  • Design 1156 74HC390 dividers.pdf
Herschel Peeler
Feb 21, 2016
401
Feb 21, 2016
401
Hello
The 74xx390 is two divide-by-ten counters. Each section has a divide-by-two and a divide-by-five part. So all you have to do is break down the count you want (in your case) into 2's, 5's, and 10's and use the sections as they are designed. Take another look at the data sheet, more closely this time.
Divide-by-two uses one divide-by-two section of one counter. Divide-by-five uses one divide-by-five section of a counter. Divide-by-ten just tie one divide-by-two to one divide-by-five and you have a divide-by-ten. It doesn't matter which you do first.. Divide-by-twenty, is a divide-by-ten and a divide-by-two. It doesn't matter which you do first. Divide-by-twenty-five is two divide-by-fives. Divide by fifty is a divide-by-five and a divide-by-ten. It doesn't matter which you do first.-
For counts other than something divisible by 2 or 5 you need to use a AND gate and take the high outputs of one of the divide-by-five sections. Straight binary stuff. (Learn binary.)
