D
Daniel Pitts
I have a signal at 0 or 5v. The source of that signal can only handle
20mA of current.
I have another circuit which needs to have the same voltage level with
reference to ground, but it could have up to 500mA going through it.
The actual current is controlled by a current sink, and it may vary over
time.
In other words, when my signal is low, I want no current. When my signal
is high, I want to source as much current as possible for the sink to
take in.
I have some BJTs laying around, both PNP and NPN, both can support the
max Ic I need. From what I figure, I'll need to hook my signal up to
the base, with at a minimum of 215ohms (Vbe = .7v, leaving 4.3v for the
resistor. 4.3v/20ma=215ohms).
Will a circuit like that work? Is there an easier way? I actually have 8
of these signals (although, only one is active at a time), so I was
hoping to avoid adding the 8 resistors and 8 transistors to my project,
though that seems to be the cheapest way.
Any advice is appreciated.
Daniel.
20mA of current.
time.
take in.
Daniel.
