I just bought a batch of 5mm white LEDs. They are supposed to be quality
units as claimed by the supplier. Considering no abuse of them, I wonder the
typical lifetime and failure modes of these LEDs? One thing is certain, they
are far brighter than ones I purchased 4 years ago.
The main failure mechanism, at least on properly
manufactured LEDs, is going to be lumen depreciation. The
LED may operate for 100,000 hours or perhaps even 200,000
hours, but will not be producing a useful amount of light.
You need to decide what percentage of initial light is
acceptable for your application and then calculate the
useful life of the LEDs used in that application from the
lumen depreciation curve. However, I suspect you don't
have a lumen depreciation curve since, as far as I know, no
LED manufacturer publishes one. Some of the better LED
manufacturers do give relative output at one point. For
example, some Luxeon LEDs are rated for 70% of initial
lumens at 50,000 hours while other Luxeon LEDs operated at
higher current are rated for 50% of initial light at 20,000
hours. Neither Lumileds nor any other LED manufacturer
publishes a full lumen depreciation curve so we can't
calculate mean lumens.
Lumileds does shows the early part of a lumen depreciation
curve for one of their Luxeon devices plotted against 5mm
devices measured by the LRC many years ago. The paper on
that original LRC experiment is still available. Go to:
http://www.lrc.rpi.edu/programs/solidstate/SSLLRCAuthored.htm
and scroll down to year 2000 and click on the link to
Narendran, N., N. Maliyagoda, A. Bierman, R. Pysar, and M.
Overington. (The only paper on this list for year 2000.)
Then see Figure 10. As you can see the data is quite old,
considering the advances made in LED technology over the
past 6 years.
My opinion is that if the supplier will not provide you with
a lumen depreciation curve for their devices or at least the
percent output after some number of hours, such as 20K or
50K, then you are taking a very big risk using these LEDs
for any commercial project. They also need to provide you
with minimum guaranteed output, not just typical, and give
you the output vs. junction temperature curve and the
thermal resistance between junction and case before they can
be used in any serious commercial project. Lumileds
provides this data, and other quality manufacturers such as
Cree and Nichia provide at least minimum output data, output
vs. Tj and thermal resistance from junction to case. Many
other LED manufacturers provide only typical output at 25C.
This data alone is useless for serious applications.
Vic Roberts
http://www.RobertsResearchInc.com
To reply via e-mail:
replace xxx with vdr in the Reply to: address
or use e-mail address listed at the Web site.
This information is provided for educational purposes only.
It may not be used in any publication or posted on any Web
site without written permission.
