Ben Parker
- Sep 21, 2015
- 3
- Joined
- Sep 21, 2015
- Messages
- 3
I have a monostable 555 timer circuit that activates a relay. This is used to turn a pump on for 60 seconds, it also turns turns on the 555 astable circuit to flash the LED on the momentary switch.
At present the momentary switch triggers the timer, however what i would like is to use the same switch to reset the timer if required. Ie if 30 secs through the cycle you want to stop the timer. I cant find the circuit i need, can anyone help?
