Hello,
I am currently working with a Wheatstone bridge containing 1 JFET to sense static fields, and the circuit is working. However, having 4 sensors in a bridge gives a signal 4 times as big. I think I have found a way to connect 4 JFETs so they are all operated by a single antenna wire and their resistances will (hopefully) rise and fall appropriately to give me a larger voltage drop across the bridge.
You'll notice that there are no bias resistors in the circuit. This is common in many static sensing circuits so I kept up the tradition. The FETs are simply acting as voltage controlled resistors anyway, passing DC only. There is no AC signals involved.
Brief explanation of operation:
The gate of T1 senses a positive voltage, for example, so it becomes more conductive. The drain side of T1 becomes more negative so the gates of T3 and T4 become negative and they conduct less. Meanwhile, T2 gate is more positive than T3 and T4 so it conducts more, just like T1. And vice-versa.
The result is 4 changing resistances instead of one so more signal output.
The FET connected to the antenna is outdoors with only the source and drain wires coming indoors. The rest of the circuit can be built indoors and connected to my current circuit.
I would like some opinions about whether or not you think this circuit would work. If not, where did I go wrong?
