4 channel optoisolator NC
fatman57
May 27, 2013
110
May 27, 2013
110
I have just purchased a 4 channel optoisolator but am unsure as to the pins - my research says NC doesn't do anything, is this correct? Also, I presume HVCC will be my voltage input line (I plan to use +5V) and HGND will be the ground. Does a separate ground need to be wired to GND on the right? Please see image below:
Much obliged for any help!
davenn
14,254
14,254
where's the opto ?
on the other side maybe ?
show us the other side
what opto is it ?
AnalogKid
Jun 10, 2015
2,884
Jun 10, 2015
2,884
If you want the isolation benefits of optical isolation, then keep all left side and right side signals completely separate. Do not combine the grounds.
ak
fatman57
May 27, 2013
110
May 27, 2013
110
ak
One thing, as I will only be using a single power supply, and will be using 5V to power both the Arduino and the load on the other side of optoisolator - so in theory they will be connected by ground anyway?
AnalogKid
Jun 10, 2015
2,884
Jun 10, 2015
2,884
Note that in post #3, I said ***IF*** you want ground isolation, isolate the grounds (duh). Of course they can be connected, depending on the rest of the circuit requirements. Which are ... ?
ak
fatman57
May 27, 2013
110
May 27, 2013
110
ak
Nice one thanks, haven't thought about this much, just running on the assumption that ground will be fine to share...basic idea is: Arduino feeds opto > opto turns PNP MOSFETS and NPN Transistors on > These power a Peltier array. All parts of the system are powered by a single PSU (PC PSU that delivers 400w of 3V, 5V and 12V)
In my ignorance ground isolation isn't really required, but who am I to say. Why would one want ground isolation? Can there be surges through ground that could damage it for example?
davenn
14,254
14,254
Cheers! I doubt its 'real' from a known manufacturer, and if it is the workmanship on the soldering isn't really up to scratch :(
I have no idea what you are talking about ???
davenn
14,254
14,254
Apologies. You linked to a Toshiba datasheet, I don't totally trust the supply chain this part is coming from
but that isn't related to Toshiba or their datasheet, aye ?
fatman57
May 27, 2013
110
May 27, 2013
110
Correct, and I really appreciate the datasheet as it has helped. Just lightly commenting that whatever logo might be on it I don't trust it.
Still my original question was: what does NC stand for?
davenn
14,254
14,254
usually No Connection or on a relay ... Normally Closed
can you trace that pin ... does it have a pc track between it and somewhere else ?
fatman57
May 27, 2013
110
May 27, 2013
110
Amazing thanks! Currently at work but will do when at home.
On multi-layered circuit boards (and I presume this one only has 2 layers) this technique isn't always possible, correct? If yes would I have to resort to using a multimeter?
davenn
14,254
14,254
it may or may not be easily traceable.... hardest part will be where tracks disappear under the IC
